Need more than 10 seconds of video
  • 1 Reply
  • 21223 Views
  • 4 Likes
kgrlamm
So far, my cameras record only in 10 second intervals. i want the camera to record the entire time there is motion and I don't want it timing out after only 1-2 seconds. I want the camera to detect motion, record immediately, and record until 15-20 seconds after motion stops. I saw that I should go to "mode", "armed", and then click the pencil. Both my browser website and phone app don't have the a spot under mode to change the record time. Where should I check next and what settings should I use to achieve the above desired results? Thanks!
FAQs are your friend.....
To adjust Arlo video recording length:
  1. Launch the Arlo app or log in to your Arlo account at arlo.netgear.com.
  2. Tap or click Mode.
  3. Select the base station or camera that you want to adjust.
  4. Tap the pencil icon or click > next to the mode for which you want to edit recording length.
    Note: You cannot adjust recording length for Disarmed or Schedule modes, only for active modes such as Armed.
  5. Tap the pencil icon or click > next to the rule that you want to edit.
    If the mode only has one rule, it is preselected.
  6. Tap the pencil icon or click > next to Record Video.
    Note: If Record Video is not selected, you cannot edit recording length.
  7. Select Record until activity stops (up to 300 sec) or select Record for a fixed length of time and move the slider to your preferred recording length.
  8. Tap < Edit Rule or click Back.
  9. Tap Done or click Save.
    Your recording length is updated.
