My house is to big for the Base station to cover...
Soooo i've manage to pull a cable from my router to the somewhat middle of the house and place the base station there.
But only 2 of my 3 cams can connect and these 2 have only 1 bar in connection and falls out sometimes.
Is there a way to get better sinal cover/boost of the base station ?
/Morten
Is there a way to get better signal cover/boost of the base station ?
No, if centrally locating the base doesn't cover all your cameras, the ONLY real way to expand your coverage is by adding more bases...( by cable or an access point/extender with an ethernet port for the second )
There in no limit on the number of bases on any level account ( nor location ) as the limiting factor is the number of cameras on your service level.
( mind that each base tho in the app/prgm will have to be armed separately )
There are other advantages ( IMO ) of adding an additional base... for example I split mine up with front and rear cams..the two bases allow you to run totally different schedules very easily.
