can you post a picture of the port you are plugging it into on your home router? it could be the wrong port, or the port could be off.
have you tried plugging the base station directly into your modem to see if it works then?
The base must be plugged into the router using an Ethernet cable. It doesn't use WiFi to connect to the Internet.
Base is prolly' defective. Return/Exchange it asap.
When granting access, you don't try to set up the system to that account. You just follow the directions in the invitation email sent to her email address.
