I have just recently purchased the four camera system with base station. I have repeatedly tried to sync the different cameras to the base station, and each time, each camera consistently fails to sync. At ll times the cameras have been within a foot of the base station but I have no success. I have read other posts and have reset the base unit, inc,using disconnecting from the router and complete rebooting the unit and connecting to the Arlo App. I am no slowly losing the will to live with these units and am considering returning them to Amazon which is a pity as I really like the concept but on the evidence today they are disappointing. Can anyone offer any advise as to rectify the failings? Many thanks in advance.
I'm having the same problem. The base station is powered and connected to the internet but the syn button won't work. The base station is a couple of feet (1 meter) away from my router, the camera are within a couple of feet. I've tried the factory reset and still nothing works. Hoping for a solution fast otherwise I'll return it to the store...
Tell us what you're doing and seeing in detail. Be sure to only briefly press the base sync button - don't hold it.
Unfortunately, issues seem to usually resolve to two causes - 1) faulty hardware and/or 2) user error. These systems do work right out of the box in most cases but there's always the possibility that something/one is causing the problem that can't be readily explained over the Internet since we're not there to experience it.
Sorry that you had issues.
