Multiple notifications for single event
I keep getting multiple notifications for a single event. It shows in the library as a single event, but I get two or more notifications every time something happens. This started happening about a month ago. Used to work fine. How do I fix that? It makes the system almost unusable. Thanks.....Paul.
Hi @Pdalglish
Can you provide a screenshot of the push notifications duplicated on your phone Lock Screen?
Message 2 of 2
1,475
