I have an Arlo Q camera and I would like to understand how mutiple zones would work. Is only the intersection of the zones used for motion detection or the union of all zones? I currently have a single zone defined which is approximately 15% but there's a small gap which I would also like to include and want to know if both are considered. I'm assuming the entire image is captured on the recording and not just the zone. Thanks in advance.
TBMK, if you setup mutliple zones, they all will be used for detection
Yes, the entire FOV is recorded , just the zones detect
