Trying to connect motions on Arlo Pro to alarm/siren. Not seeing this option.
I am trying to connect the motions on our Arlo Pro camers to the alarm/siren (i.e. when motion is detected the alarm goes off). It looks like from what I read that you go into "Mode" and select the camera and edit to get this to work. Well...the only options I have are that when motion is detected I can select "Record" or "Do Nothing"....I don't see a placeto trigger the alram except to do it manually. Very confused and searched all the menus in the app and all I can see if how to activate the alram. Help!
When editing the rule, use Add Device to select the alarm.
