Motion where none exists
If you use the SHARE feature in the Library, you'll get a address you can copy ( use copy link ) and paste in a messg... shared links last only 24 hrs and then poof , they are NG
I have noticed with my cameras that the motion detection is probably 20 degrees greater than the video capture. I have noticed the recording starting a few seconds before someone on foot gets into the view of the camera itself. You may be picking up motion that remains out of view of the camera due to the wider range of motion detection as compared to the video capture. If I were to make an educated guess about my cameras, I suspect that the motion detection is around 140 degrees and the camera captures around 120 degrees.
https://arlo.netgear.com/hmsweb/users/library/share/link/AD37E2D0C7EBAC10_201708
https://arlo.netgear.com/hmsweb/users/library/share/link/AC7D454BC59F744C_201708
https://arlo.netgear.com/hmsweb/users/library/share/link/15E8BF4C5DF6296A_201708
https://arlo.netgear.com/hmsweb/users/library/share/link/6FF471C2FFC0EC3F_201708
Mine do that too. There is some sort of flash/flicker at the very beginning. I haven't found any settings that resolve it and it's not a regular occurance. I thought that maybe it was the way that the sun was hitting it, but it does it at random times.
It can sometimes take some trial and error to find optimal conditions for your Arlo system.
Take a look at the tips in this article to be sure your cameras are positioned for best performance: How do I optimize my Arlo Wire-Free camera’s motion detection performance?
