Motion sensitivty
So I have noticed I am capturing clips that have nothing in them, only triggering after someone has walked through the capture zone.
Putting this down to sensitivity, I can see where to change it but I cant work out the scale.
0-100 : Is it more or less sensitive at 100? The icons indicate at 0 a figure stood still so I would suspect that would pickup less movement?
Higher number more sensitive...
Many of mine run at about 90%
