I have an Arlo Pro and a Pro 2 camera connected to the same base station. The Pro 2 is working normally but the Pro is not detecting motion during daylight. At night it will record motion with a passing rabbit, but during the day even humans walking across the field will not be recorded. I can connect to it a see live views and the settings for recording are the same as the other camera. I would appreciate any suggestions. Thanks
This is new - in the past it was "records during the day but not at night".
What mode are you using? Have you tried creating a new custom mode with the same settings? It's possible removing and resyncing the camera may help.
Mode = "armed, motion detection on". That mode controls both cameras - the other works fine. Will try re-synching. Thank you.
