		6 REPLIES 6
yes.... audio will work fine
( no siren or local record as those are physically on the Pro base )
It looks like it is sinking ok but i am unable to see it on my viewer.
do you mean the camera is sliding down the base mount?
I think he means "syncing".
Try power cycling the base.
i meant syncing.
