Max Arlo pro camera distance from router
What is the max distance I can keep the camera from the router
In the threoretical world about 300ft
In the real world, it depends on what the wifi signal must travel thru ( shreetrock, concrete, metal duc work, mirrors , etc )
Overall, it's prob between 30 and 100 ft
( had one out to 150+ft but thru one wall )
There is no single answer. If your Arlo signal strength meter is low get a cheap range extender with an rj45 jack and relocate the base.
