Magnet mount is Weak for Arlo Pro
The Magnet Mount is weak for Arlo Pro. The camera is not standing where I want it to be and this is disappointing.
I'm guessing you have the camera positioned slightly outside of the normal rotation of the magnet. Try playing with the different positions on the magnet mount and you'll see which position's give's a better grip.
I've never seen my camera move on these mounts, even when almost upside down. Just play with the positioning.
Two things:
1) temporarily use a small piece of balloon between the camera and mount
2) contact support and open a case. There's supposed to be new mounts with a slightly rougher texture or an RMA for the camera. I have two newly RMAed cameras (for a different issue) that seem to have a different piece of plastic on the camera which has prevented the camera from rotating since I received them.
