Stopped recieving notifications on 2 IOS 10.3 Iphones. Still recieving emails. Spent 3 hours with phone support resetting everything--Phones, Base station and camera. Deleted and reloaded app. triple checked phone and app settings. Have started a case but have not heard back. I like the ease of use of the camera but not having notifications is a problem and is key to its usefulness.
Who else is having this problem after verifing everything? Were you able to resolve it?
Appreciate the help!!
Ok Thanks--I will give it a try
I've tested this and did not experience any issues receiving push notifications. Are you still experiencing this issue?
No Resolution on 2 phones Iphone 6 and 5 both runninf 10.3.3 ----waiting for elevated support response---nothing so far.
Online Comment 9/28/2017 8:34 PM
I have a pro with a solar panel attached and was receiving notifications on my Iphone 6--ios ver10.3.3. Notifications stopped working 2 weeks ago. I was on the phone with tech support Tuesday night for about 3 hours trying to get notifications to work. We did it all---checked settings-- re boot everything--reload app, reset base to factory settings and had tech support logged into the camera and they could not get notifications on their ipad. So with all of that it was decided that you would be elevating this to the next level of support and i would be notified in 24 hours of progress. Please advise where this is at. I do receive emails--but I want notifications.--
Nope---still does not work. Agreed it is worthless without notifications. For what its worth Ring is coming out with a wireless version.
I'm not sure it will work but it may be worth resetting everything and start fresh. If still the same problem, resetting and creating a new account might be useful.
I have reset everything twice no change. Customer sevice logged into my account added the selves and were unable to recv notifications. Maybe it is best to replace the base and camera with latest versions and start over.
I've escalated this topic for further investigation. I will post an update when I have more information.
Interesting
Are you getting "push notifications" as well as email?
I will give this a try---
What was the process you used to remove your orginal account and registration information and recreate a new account?
Thanks for your help.
Thanks---That did the trick---all is workinmg just fine now
