App Crash
- Email to a Friend
The fact that there’s whole threads where people are saying the people detection doesn’t work just proves Netgear/Arlo doesn’t care what it’s customers think.
- Email to a Friend
- Email to a Friend
- Email to a Friend
When I go to "Live Feed" my entire iPhone X freezes up. Unexceptable - please help!
- Email to a Friend
Same here!!
- Email to a Friend
I have an Arlo Pro. Base says it's VMB4000 model, and we've had it for quite awhile.
My wife has started having issues with the app used to access the camera, and give the notifications
It's started randomly crashing and saying 'Arlo has stopped.'
Phone is a Samsung Galaxy S9 Plus, which shes had and used with no issues since June, and there's been no updates or anything installed anytime recently. We've tried clearing the cache, clearing all the data the app had stored, and then reinstalling it. No idea what the issue is, I have the same phone and have had no issues. Can't seem to find anything online with the same issue, if anyone could help me out I'd be grateful. Thanks.
- Email to a Friend
BOTH -- crashes on wifi & cellular
- Email to a Friend
- Email to a Friend
I am having the same problem
- Email to a Friend
I am having the same issues
- Email to a Friend
- Email to a Friend
Arlo crashes my iPhone Xs Max so bad, I can't even reboot the phone. I literally have to wait for 2-3 minutes for the phone to just snap out of it, and reboot the springboard on its own. An absolute mess!
- Email to a Friend
- Email to a Friend
I called support as I am having the same issue. They simply said the developers are working on it and that it is a "known issue".. but no estimate or projection of time for a fix. Arlo is going downhill very fast.
- Email to a Friend
The Arlo Development team is currently investigating this topic. I will provide an update as soon as I know more.
- Email to a Friend
my xs max locks as well when tyring to go live.... NETGEAR/ARLO PLEASE FIX THIS
- Email to a Friend
iPhone XS Max - same thing. Utterly useless. This needs to be fixed imediatly.
- Email to a Friend
- Email to a Friend
- Email to a Friend
@Battman wrote:
an acceptable solution has been provided. Sign up for apple’s beta testing program (super easy) and install the latest public beta. It works.
Are you stating that iOS 12.1.1 beta fixes the Arlo problem or that there is a beta of Arlo 2.6.3 or patch update of 2.6.2 equivalent available?
- Email to a Friend
Thanks for the suggestion, but it's not a viable solution for most. We shouldn't have to enroll in the Apple Beta program and upgrade our iPhones to a beta version of iOS in order for Arlo's iOS app to work correctly.
- Email to a Friend
I contacted Arlo - talked to a tech. They are having an ongoing problem and hope to have it solved by next week
- Email to a Friend
- Email to a Friend
Sam issue here, I have deleated the app and restarted and still freezes
I have the Iphone Xs
- Email to a Friend
