Arlo|Smart Home Security|Wireless HD Security Cameras|NETGEAR
Re: ARLO Pro/Pro 2 iOS and Android Apps video Feed Issues :- Iphone XS Max Arlo App 2.6.2 on IOS12.1
Please Development Team let us know when the next version post 2.6.2 will be released and let the Arlo community know, so we can at least have an idea when we can use the product again
Live view is unusable and hangs my Iphone XS Max every time, you can't even click the side buttons
Please urgently fix and release a new version soon
This is the worst version of Arlo IOS app I have ever experienced in the last 2 years , at least previous versions did not hang your phone .
You have such an excellent product I have had very few issues with connectivity and I have 9 cameras.
But all the new software releases are destroying your reputation, together with your outdoor power cables which were advertised as waterpoof but were not, even though you issued a recall, who will pay for my electrician to go up on the roof and replace 8 cables, this was an extremely disappointing state of affairs.
I have spent over $2500 on your system and my confidence level is getting lower with every IOS Arlo app release.
Please listen to your users and field test your software properly before releasing it.
Model: VMC4030 | Arlo Pro Wire-Free Camera
Message 101 of 535
Re: Arlo iOS App 2.6.2 issues
I have the same issue !!!
Please Netgear fix this ASAP
All Arlo Community users please add to this thread if you are having issues with
1) Iphone X or XS MAx
2) IOS 12.1
3. IOS Arlo app 2.6.2
Developers please give us an ETA to 2.6.3
Message 102 of 535
App Freezing when Live Streaming
I’m having issues with my app since the update 2 days ago. Every time I open the app, it functions fine, but when I go to live stream one of my cameras, I can hear audio but the screen is completely frozen. I have to soft reset my phone every time just to get out of the app. Anybody else experiencing this/have a solution?
Message 103 of 535
Re: Arlo App Updates Crashing 11/21/18
Yes. Arlo will not open. Nov 22 18
Message 104 of 535
I read a thread on Google to go back to the last update, "2.6.2_22800"
I downloaded it and got my camera surveillance working again. I don't know how to disable automatic updates, but at least it's back and working for now.
Good luck,
Model: VMB3000 | Arlo Base Station
Message 105 of 535
I have same issue mate. No live viewing. Frozen my phone. I got iPhone XS MAX 12.1 iOs
Message 106 of 535
Re: Arlo App locks up
Latest Arlo app crashes on startup for me too.   Previous version was fine.   Since upgrading to 2.6.3_23000 there is an issue.    Tried uninstalling and still have issues.   Please could the devs fix ASAP.
(Google Nexus 6, running LineageOS, Arlo Pro / Arlo Q cameras)
Message 107 of 535
Re: Arlo App IOS problem
You didn't contact Arlo support - it's free. Stop Googling for support and use the links here. Use the Contact Support link at the bottom here and again on the new page. On the 3rd page are options.
I would run complete scans on your device to try to remove any possible malware installed by the scammers if you allowed them access.
Message 108 of 535
Sir,
If you can download the earlier version of the update from October.
This will get your system back working. Uninstall the newest version first. Then install 2.6.2_22800
You can get it on Google as a free download.
Worked for me.
Robjames1960
Message 109 of 535
Mine started working again late last night but no upgrade to the app as far as I can tell. Anyone else seeing it work now as well?
Message 110 of 535
App crashing on ios
Every time I open app and hit live view it freezes my iPhone X’s max and app crashes. Needs fix ASAP
Message 111 of 535
Same. Locks up and crashes iPhone XS Max when trying to view a camera. Everything worked fine in the previous version. Using Arlo Pro 2.
Model: VMC4030P | Arlo Pro 2 Wire-Free Camera
Message 112 of 535
It’s still locking up my iPhone.
Message 113 of 535
Re: Arlo and iPhone MAX and IOS 12.1 - Do not work
Since I have switched to new iPhone X Max, IOS 12.1 Arlo app crashes, locks up, or reboots the phone.
Mainly reboots phone.
Have uninstalled app restarted phone and nothing seems to help.
HELP! PLEASE!
Is there a solution to this?
Message 114 of 535
Ok this is a long shot and I don’t know if this fixed it. But right before it started working I went into iOS settings scrolled down and opened Arlo and switch on the ‘classic UX’ switch, then opened Arlo and viewed live video and it worked. I then switched classic ux off and it’s continued to work so far.
Message 115 of 535
Re: 2.6.2 is broken
Do yourself a favor and return the system. It's literally junk now.
Message 116 of 535
Re: Arlo app is causing my iPhone XS Max to crash
Same - app completely crashes every time I try to watch a video, live stream or otherwise. This morning, had to hard reset my Iphone XS Max. Latest software iOS update installed, and deleted and redownloaded Arlo app - did nothing. FIX THIS PLEASE, I use this for my baby monitor and live in a city that is NOT safe, especially when burglary increases around the holidays.
Model: VMC4030 | Arlo Pro Wire-Free Camera , VMC4030P | Arlo Pro 2 Wire-Free Camera
Message 117 of 535
There is no solution yet except downgrading the app by installing an older build found on Google (works for some poeple). Arlo has not yet acknowledged this as an issue and that should be the first step
Message 118 of 535
Re: Arlo Baby - iOS 2.6.2 is BROKEN/UNUSABLE
Arlo is a joke. The last two upgrades either crashes the iPad or iPhone. Version 2.6.2 now crashes the iPhone. Everyone, please tell people not to buy this product. The company is terrible in replying to bug issues
Message 119 of 535
This software issue is a joke. Tell everyone you know not to buy this product. It has not worked since version 2.5.1. All of versions 2.6 and higher do not work and they they crash the iPhone   They are clueless how to fix it and release upgrades without any testing. Just buy an iPhone and install it and you will see that it doesn’t work. Tell anyone thinking of buying this product.
Message 120 of 535
Re: App crashing on ios
Same here! Very frustrating!
Message 121 of 535
Fixed!! Hello strange fix for IPhone xs max but try this it worked for me.
Exit app and force close it.
Go to your control center and start a screen recording.
Go back into arlo app and it works fine. Try this
Make sure you force close arlo before starting screen recording.
Message 122 of 535
Are you referring to Arlo update? Where on google do you find it?
Message 123 of 535
Highlighted
Same issue here...broke on the latest update.  iPhone Xs Max - 5 cameras mix of Arlo 2 and original.  Contacted support - they had me try a few dumb things as usual.  You really have to wonder if they test this stuff.  We should start a Go Fund Me so that they can all buy the new iPhones or give them a pot of money to hire us to test for them.  C'mon Man!!
Message 124 of 535
Re: iPhone XS Max crashes
i have the same issue. is there a fix for this.
Message 125 of 535
