Lighting bolt
  • 1 Reply
  • 828 Views
Retired_Member
Not applicable
My cameras are all set up but after 4 hours of charging keeps saying needs update low battery. The lightning bolt doesn’t go away,why?
Try fully charging the battery first and then see what happens. Also, are you using a solar panel or outdoor AC power? A solar panel can only trickle charge so heavy usage and/or poor connectivity can still drain the battery.
