Hi all
When you have set a camera mode to trigger the arlo base system alarm on the detection of motion, how long will the alarm sound for after it has been triggered before it is automatically turned off/reset?
Also, is there a setting to control the length of time the alrm sounds?
I understand (and have used) the manual option to turn off the alarm after it has been triggered by the camera, however if I am unavailable to manually turn it off, I am curious as to how long the neighbours will have to endure the noise of the alarm!
Thanks in advance 😉
Josh
Yes, there are adjustments in the Rules section for the cameras attached to the Pro base station for adjusting both the duration, (1 minute to 5 minutes), and volume.
Brian
Brian
Many thanks Brian. Found it, sorted it, done!
Cheers
Josh
