The app on my iOS devices seems to be acting strange. I had several events not record today, so tonight I was navigating through the settings via the app. I noticed that several of the cameras lost the record setting in the rules. It also seems that one of the cameras has lost the push notifications. Now I cannot find the setting to add the push back to the missing camera. I also cannot find the setting for record lenght.
The issue seems to be with both iPad and iPhone. Both have iOS 10.1.1
The app version is 2.2.0
I did update both iOS devices earlier this week. The issue with the cameras not recording started today.
Anyone else using iOS have this issue? Tomorrow I will test the cameras and log into the Arlo site using a desktop computer. Will see what happens.
I have to say this, the web version of editing settings works much better than the app.
If the PC works ok...then obv you should delete the app and re-install.
If the PC is messed also, then you may have to do a full reset of the base to restore defaults and re sync the cameras as if new
