Is there any type of tint that can be used in front of the camera lens?
I'm using a birdhouse to hide my camera. However, if you look directly at the birdhouse you can see the camera inside. I was just wondering if there was any type of material/ screen, like tint, that i could use in front of the lens that wouldn't effect operation of the motion detection and conceal the camera a little better.
Thank you!
Thank you!
I wouldn't put anything over the front plate sincethat would likely degrade the performance. However, if you want, you could certainly use some coloring on the white case, it that's what's noticeable.
