Is there a way to program cameras to monitor at different times?
I have an indoor and outdoor Arlo Pro and would like the indoor to alert me at night and the outdoor to record only. Then during the day would like the outdoor to record and the indoor to turn off. Any way to do this? Thanks!
I with you regarding setting certain devices to be on alert vs's at certain times vs's all of them at once.
I have 2 cameras outside and 2 inside. Id love to be able to arm the 2 that are outside to notify me when there is motion during the night, while ignoring the inside camera as they usually pick up us walking about inside the house.
Sounds like you need to create custom modes. There are FAQs here that step you through the pROcess. Basically, use the Mode tab, select your base and check out the Armed mode. Then create custom modes with rules that you need. any camera without a rule is disarmed. Once configured, set them into the schedule as desired.
