Is the Arlo Pro outdoor power adapter plug weatherproof?
  • 1438 Views
Dee888
I have the VMA4900 outdoor power adapter for Arlo Pro. Is the plug weatherproof? I live in an area that gets weather below 0°f and most summer days it's rainy. I think I may return the outdoor power adapter, since I will need to get on a ladder to either recharge the batteries, or plug in the power adapter. Oh well.
The outdoor power supply has a seal that, when properly and fully installed, is weatherproof.
Dee888
I was referring to the metal plug
michaelkenward
Sensei Sensei
Sensei
All outdoor electrical devices need a waterproof socket of some sort.
My outdoor adapter sits in one of those.
Something like this:
81qzaxYrZAL._SL1500_
It is also possible to use a  Weatherproof Enclosure Box:
71P6L0urVxL._SL1500_
You can put an extension block inside it to power several devices.
Just another user
