Hi guys, I'm thinking of buying a new camera, however, I know the regular Arlo cost less than the Arlo Pro, I'm aware that regular Arlo doesn't have 2 way radio and I'm ok with that. The question is, if I buy a regular Arlo camera, is it compatible with Arlo pro system? Will I be able to sync and use it with no issues other than no 2 way radio? I'm just trying to save a few bucks by buying a regular Arlo instead of Arlo pro camera. Thanks!
YES... either camera will work with either base...your good to go
Great! thanks, I was hoping to hear that.
