Why does my camera night infrared come on when I have the camera set to off?
YES!!! My Arlo Pro's batteries are draining incredibly fast all of a sudden (after the update?)!!!! This is too much......I hope they fix this soon. I believe I made a mistake going the wireless route! Before this last update, I was really happy!
One of my arlo cameras has been just going through batteries faster and faster everytime now. This is my inside camera so the environment is the most stable. This is my least used camera as well, it is off most of the time and has only logged a few minutes of use monitoring and recording per the last two sets of batteries. It seems that the battery drain is occuring when the camera is off, this last time it ate the batteries in a week's time with only a few minutes of use. The camera is about a year old and the newest of my cameras. The firmware is the same as my other cameras 1.2.16720
I have 4 other cameras and have used the same kind of batteries for years and never had this kind of an issue.
These are the basic Arlo wireless cameras.
I should mention that when this camera was new, the images would be pink in transition from night vision to daylight, but It has not done that for a long time. Do not know if that has any relevance.
I keep reading about a trial firmware update that seems to help with the rapid battery drain I'm experiencing. How does one download that update?
I returned my kit on warrant due to the battery drain. Got a completely new kit. Still same problem... Last time battery lasted for 6 months, now 2 week with NO change in settings.
So when will they release new firmware to sort the problem????
Was offered the trial, but think I'll just wait until the production release. With the bad luck I've been having with my system since the last couple of updates, I'm certain something will get thoroughly borked. If its a production release, and a lot of systems get borked, then Netgear will be a bit more timely about fixing it... maybe... but... huh... given their response to this latest bork... probably not...
Fireware updates should not be pushed on us - we should be allowed to download and install them when and if we are ready. And Netgear doesn't bother to notify us when they are going to push out these updates, either - so they have us chasing our tails the next day becasue functionality is borked and we have no idea what happened, or what's going on...
That's like me installing updates for my clients' system and not bothering to tell them... you just can't do that. Even with all the testing in the world, updates casue issues - and different issues for different systems/setups because no two clients will ever use a system the exact same way. And its like this with Arlo, too... so a bug that affects me and my setup/usage might not affect you and your setup/usage.
@Wklovelace3 wrote:
Just hope we dont have to go thru this with every major release. That was the problem 3 releases at once.
Got my 1st Gen Arlo May2015 and Added Pros early last year.. Eversince then, Every new updates have issues, some were not too bad and some just annoyingly bad like this one we're in right now... I hope so too but thru the years my experienced sadly it's the same crap we customers have to go thru with the new update release(s)... It's indeed scary coz' you'll never know also if your system will end up bricked and nothing to fall back on instantly..
Good to hear the field trial is working for you... I hope Arlo will release the final production before it's too late..
For the field test, did they download new firmware to you Arlo Pro cameras? Or new app or both?
Glad to hear it is still performing.
I've had this system for over 3 years and never had an issue, in the last 3 months I have a total of 5 cameras and 3 of them will not hold a charge for more than 1-3 days. I've swapped the batteries to rechargeable, back to out fo the box, move locations to even a foot away from the base station, but they still only last a few days. I've reset the entire system, added them back, changes locations and yet nothing works. I'm really just considering changing to another brand.
Specs are:
Base - 2.5.3.899_21733
Camera 1-5, each are H7
1.2.16720
1.2.16720
1.2.16720
1.2.16720
1.2.16720
I think we all understand that things break, softwae has bugs and a new bug might have been introduced in the latest update. That's fine, it happens. What's really upsetting is how Alro handles this.
Arlo has to say we know there is a problem and we are working to fix it as soon as possible.
I called phone support, but they are completely clueless. It's emberacing.
Most of us spent a lot of money on Arlo cameras. I'm going to make a guess and say that most people spent $500+. Alro should be able to provide support not for just 90 days (look at Apple).
Again, it sucks when things break or don't work but we all understand it happens. The issue is how Arlo handles. You need to admit that something is not working and you will fix it. Right now it's a big fail.
