I would like to add a camera in my barn which is more than 300 ft from my base station. How?
  • 1 Reply
  • 1361 Views
Mucksal
I would like to add a camera in my barn which is more than 300 ft from my base station. How can I do this?
If using a Pro camera, you prob best solution is to run Ethernet cable from you router out the the barn... max distance for cable is about 300 ft...  so it would be close....and then with power set up another base and or  second system ( shared back to the first account ).
Or , a Q type camera ( Q plus ) can run on POE ( power over ethernet ) so it can just be a single cable if no power.
Or a cellular modem ( data plan ) with an ethernet port will work if good cell service
