Sirs, I am remote and have no access to my camera or the serial numbers. I accidently disconnected my camera while trying to cycle it to boot it back on by hitting "remove device." Is there any way to turn this back on? I will not be near this camera for several weeks and have no files with me. Thank You
If you removed the camera from your device then you will have to re-sync the camera just like starting over when you bought the system.
