I have the 2 camera Arlo Pro system - 1camera disconnects randomly
  • 1 Reply
  • 2763 Views
mura2112
i installed my Arlo Pro 2 camera system yesterday and 1 of the cameras keeps randomly disconnecting.  The second camera has been working perfectly.  the longest it has stayed active is approx. 2 hours.  the battery is showing uo 90%, but when i remove it from the mount & plug it into the wall charger, it automatically reconnects.  the "sync" button on top of the camera is getting stuck sometimes.
I would swap the two camera's locations... to see if it's the camera or placement area
If the problem follows the same camera, then contact Netgear
As to the sticking button, that's a Netgear trouble report if need be.
