i get the message saying my device isnt trusted please use the verify. I have the push method and that phone is the same. I am not getting any push messages. I cannot use the email method because that email is gone now. I have tried loading the app on my samsung as well as trying to login on the computer. Tried deleting and reloading on the computer as well. Deleted the cache no change.
What are my options here? Throw these good cameras away and go with a different type? There is no one to call so i need to know my options here to move forward.
Thanks for any advise.
You could try private messaging one of the arlo moderators here on the forum, @JamesC or @ShayneS and state your case.
The next step is to contact arlo support and raise a case. Refer to the settings page of the app or web portal if you need a number to call. The more cases the higher the escalation goes.
Of course you will need to have a subscription plan.
Thanks for the reply, and that is what i have been reading. I do not have a subscription so i guess i am SOL since i will not pay to maybe get this resolved.
BUT, how can i just deinstall all the cameras and home station and then reinstall it all using a new email and phone number? Is that possible? That is all i can think of doing other than just tossing the cameras and getting a different type of system?
how do i do that?
@Jmoxie772 wrote:
how do i do that?
You can send a private message (PM) by clicking on the envelope icon on the top right of the forum page.
