I can only get Library for one of my 4 cameras? How do I show the Library for all 4 cameras?
Make sure the filter is tuned off OR set for all cameras
Go to library, click on filter ( looks like a funnel ) and hit reset ...make sure it says ALL CAMERAS ...save
Thank you so much!
Leslie
Also in the future... if you go to live screen and see a number in the circle next to the gear icon...click on the circle.
It automaticly turns on the filter for that camera so in Library you only see that camera...
Just remember to reset the filter to see all
