I Lost my 7 Day Recording
I lost my 7 day recording capability. Does anyone know how I can get it back? Thanks.
How do you know you lost it? Exactly what are you looking for - videos in the library or how to ensure recording is enabled? For the former, make sure the filter in the library tab isn't set - the funnel icon at the top should be empty, not filled. For the latter, are the running men for the cameras in the Devices tab black or gray? Gray means they're disarmed - use the Mode tab to select the Armed mode.
