How to trigger siren automatically
  • 5 Replies
  • 9108 Views
jkshining
I have recently purchased Arlo Pro with base station and 4 wireless cameras. Base station has an inbuilt siren. However I am struggling to find the option to automatically trigger the siren when motion is detected. I check out the "Edit Mode" option within Arlo App, but it only gives the option to "Push Notiication" and "Email alert" when motion is detected. Siren is not an option. Please can somebody help?
5 REPLIES 5
Click on the Add Device selection while editing your rule. The siren can be found there.
Leifdanielsson
The recommended option does not appear. Trying from both IOS app and MacOS Safari. Is there a browser/operative system problem?
This is after clicking on the Add Device button while editing your rules?  If so, can you verify that you actually have a Pro base that has the siren and not the original base which does not?
Leifdanielsson
Found it, eventually. Instructions were a bit confusing, as I didn't realize the siren was a "new device".
But sure, makes sense, although I think to an amateur, that is a step too technical - to me it is already in the base station device...
It does take a little bit of a mindset but you're not adding a new device, you're adding a new device to the rule. Perhaps the Add Device selection in the rules should be renamed so as to not be confused with the Add Device button on the web interface in the Devices tab.
