  • 4 Replies
  • 4633 Views
  • 3 Likes
Dwhite112
I have arlo pro I have it set to record for the 300 seconds settings but still records for most of the time 10 seconds
steve_t
Master Master
Perhaps you're missing the critical part about clicking SAVE when you make the change to the recording time or motion sensitivity??
If you want to record til motion stops, that's a different check box to tick in the recording setting. Again, don't forget to go back and then click the SAVE button
jtalbot13
I've had mixed results with this setting but my theory is that you have to create a brand new rule with the "record until activity stops." The majority of all my recordings with that setting using the "Armed" mode, are all 6 or 10 seconds. And that's what I initially picked when setting up the rule almost a year ago.
Give a new rule a shot and see what happens.
DuncanYB
I have it set to a fixed number of seconds for this reason. Also note that when you go to the live view the recording stops automatically and you need to click record manually if you want to capture what is happening.
steve_t
Master Master
Yes! That was the other issue from that thread the other week. Person gets notification of motion and opens app and hits Live view not realising that it cuts the recording off
