Hi
I have been given the run around with Arlo . After processing my RMA and me sending a device back to Arlo ( tracked royal mail) . They seem to have no clue where the device is nor when a replacement will be send.
The chat and phone support has been absoutlely unhelplful, with the same canned answer. With no resolution.
Is there a way one can esclate a case within Arlo?
case id 40796839
Hi @arunnair
After reviewing your case, it appears you are being sent another RMA device, is there another case regarding the issue not being resolved?
One of the worst customer service I have ever seen. I was quite happy with device till I had to deal with support. Now I would never recommend arlo to anyone else. Atrocious customer service...
Hi @arunnair
We apologise for the poor experience you received with support, after reviewing your case, it looks to be in the process of being resolved. I will contact you via PM with further information.
Hi
Thanks for sending the camera. However, why does Arlo make everything so diffcult??? I received the camera today without a battery. I am nto sure if its the pro or wire free they sent.
I had sent my Arlo pro back with its batteries!. Do i need to send this back and new one with battery will be sent ?
The instructions should have said to send only the camera, no accessories. At this point, contact support again to see if they can help or if you need to buy a new battery.
