How to download videos?
How are you supposed to download video. There are links, but they do not work. And the software sucks as it is not user friendly.
You don't say what your using app or web....
but in both cases download isn't that hard from library to d/l local.
In web , you just select each video and then click download
In the apps , once you select video and then press on 3 dots (android) for menu to pop up.
for multi downloads on same day, it hold on vid and then options come up for slecting more
