Hi I have six Arlo Pros on one base station and I need to add more cameras thanks to a horrible neighbor. How many cameras can I put?
Up to 15 although only 5 can stream at once. You might want to consider buying a second system with a base so you can have more streaming at once. Of course, make sure your upload speed through your ISP will support that bandwidth usage.
Up to 15 20 although only 5 can stream at once
Fixed it for you Jeff 🙂
You sure it's 20? For a long time it was only 15 and the Elite subscription was 15. Elite is now 20 - maybe that's the difference?
@ShayneS true enough but how many total cameras can a base support? It's not a subscription issue but hardware and/or software.
