How do I turn on/off email notifications?
  • 6 Replies
  • 7665 Views
  • 2 Likes
  • 5 In Conversation
demetriusdvc
I have received more than 1000 emails per day from moving the cameras, but I want to interrupt the test procedure.
how do I do?
6 REPLIES 6
mbauer
Go to the Mode tab, select your system, edit the various modes, turn off email notifications. You can also enable/disable push notifications to your device.
sparky208
I am trying to turn off email notifications.  When I go to mode it does not give me a camera option.
sparky208
I figured it out.
heythere1
When in Mode the only device showing up in MY DEVICES is my base station. My two named and functioning cameras aren't there. I' m trying to access motion and audio detection rules for my cameras. Can someone help me correct this issue.
Sure - click on your base.  The modes are then displayed. You can then edit the modes (Armed by default) to check and change settings. Consider creating your own custom modes instead so you have full control.
