How do I stop verify ID? it ask me everytime I sign on.
thanks
What device are you logging in from? - a phone/tablet (using the app), or a PC (using the browser)?
StephenB,
My PC.
I use AOL & it's so slow to load that most times the required 2:00 minutes run out. So now I have to go on AOL 1st then ARLO. I have two houses to look at and it sucks.
@cstrait22 wrote:
My PC.
Are you trusting the browser when you log in? While I don't find that lasts for 2 weeks, it does last for a few logins anyway.
Not sure why AOL email would be so slow to load (it's not something I use myself). You could try getting a gmail address, and if that loads faster for you, then you could switch your Arlo login to use the gmail address. You could of course continue to use AOL for everything else.
Still waiting for the option to TURN 2stage OFF...
I get a couple of logins and then it requires a security test. Esp when I turn VPN on/off.
