Hi can anyone help or advice i have Two arlo pro wireless cams i am trying to get the wifi range signal the same on both cameras by moving the netgear router and using a wifi extender with ethernet cable . I do acheive this but after a short time One camera starts to get a stronger wifi signal? Really confused? help?
cheekychicco,
Are loosing connection or having a performance issue with the cameras? The signal may have a slight fluctuation depending on the obstructions and distance. There may be a 2.4 ghz frequency interfering as well. Phones like to operate on this same frequency.
Hi thanks for your reply i am not loosing a connection just seems to be low on one camera or the other i have moved the netgear modem to a central place but still one camera seems to have a stronger wifi signal i am aware of wall beams etc can affect this but they work ok just not sure why the wifi signal cannot be equal to both cams
