Help with adding a camera
  • 2 Replies
  • 2045 Views
Tiny31409
I'm tryingto add a camera. Wheni hit add device it tells me to plug in the base station, it's already plugged it and running. I already have a camera on it and can view that camera.
How do u get a second camera?
If the base is online and functioning...
for the older cameras like Pro / Pro2,  you can manually sync the cameras directly.
Just get within 3 ft of the base, quickly press the base sync button ( led on base for cameras should flash ) and then press the camera sync button... slow camera blue led to fast blue means it worked.
BTW, it rather sounds like you selected to add a base station rather than a camera.
