Take a look at this KB where it mentions the blinking green internet light.
https://kb.arlo.com/989/What-do-the-LEDs-on-my-Arlo-or-Arlo-Pro-base-station-mean
There are already 3 other posts about this.
This inernet flashing light is normal. It should have always been there as per the documentation but the firmware had not yet caught up.
Thanks very much for taking the time to respond to my post. FYI, I had looked through the Q&A's but apparently missed the three posts which addressed my issue. I also read the user manual (Arlo Pro Wire Free HD Security Camera System) and found on page 8 a photo of the base station and a description of what the different lights on the station meant; however, the page did not show an explanation for a green blinking light for the internet. If you don't mind, can you reference the page in the documentation which references the green blinking light for the internet so that I can have it for future reference? Thanks -
I believe this is a result of a recent update - my base station is only a few weeks old, but my manual does not show the green blinking light info referenced in the kb article. So that's probably why you didn't find it in your manual.
Very helpful. Thanks for taking the time to respond.
I see it. Thanks for responding.
