Geofencing goes from armed to disarmed seemingly at random when I am at home. I can’t determine if my iPhone 6s is at fault or if my base VMB4000 is the culprit. Any help is appreciated
tmcd,
For Geofencing to work, the app needs to be running on your device. Are you logging out of the Arlo app? This would cause the symptoms you describe.
