× Urgent: Activate Two-Step Verification
Arlo requires all users to activate two-step verification by Nov 30th, 2020 to continue to access your recordings, devices, and account.
Please enable this feature now. Learn More.
Re: Geofencing problems
Highlighted
It recognizes that you are @ Home - that's not the problem.  Create couple custom modes and set it to use them while @ Home -- it will work.  It just does NOT work with "SCHEDULE" !!!
Model: VMB4000 | Arlo Pro/Pro2 Base Station
Highlighted
Hi
I note that there are several post relating to the unpredictability of geofencing
Over the past few weeks my system recognises away mode as sets the lark to active but when I return I receive notification that I am entering home zone but the system does not reset to home mode and deactivate
The only way I can resolve this is to manually disarm and then select geofencing I then receive a you are in home mode and the system is disarmed
I have reset all settings deleted and reinstalled the Arlo app which is the latest version
I am using the app on iPhone 6
I also note several posts suggesting that more app fixes are due shortly may I ask if these are likely to fix this problem or do you have any other suggestions
Thankou
Highlighted
Sensei Sensei
Sensei
Most of them describe exactly the same issue that you report.
Catch up here on all the stuff that you missed:
Geofencing not disarming when I arrive home after ... - Page 10 - Arlo Communities
Just another user
Highlighted
Same problem for me with an Arlo system. Has Netgear even acknowledged the issue?
Model: VMC3030 | Arlo Wire-Free Camera
Highlighted
Have the exact same issue for my wife and I iphone ;(
Please help!
Model: VMB4500 | Arlo Pro/Pro2 Base Station
Highlighted
I am having the same issue.  I only have Geofencing on my phone - Samsung S7.  This isn't just an IOS issue. It affects Android as well.  I have it set to Armed when outside radius and schedule inside radiius. I then set up the Schedule to be armed from 10pm to 6am no matter what.
I come home and the system does not disarm. I have tried, small, medium and large radius. I can be sitting in the living room with my phone in hand and the system still gives notifications and records.  This causes unnecessary drain on batteries and extra videos to filter through. I can leave my phone in the house during the hours of 6a to 10p when it should be disarmed and the system picks up my every movement.
When is Arlo going to correct their Geofencing.
Also, my notifications seem to store up and wait until I actually pick up my phone and open an application.  Then I get dozens of notifications for the past couple hours.
Last update on Google Play shows 5/23. Nothing new since then.
Highlighted
They know. Unfortunately, the new build didn’t fix it and I still get inactive activity zone warnings due to AC being disconnected.
Highlighted
My wife and I are geofenced. The mode identifies that we’re home, but won’t disarm the cameras. I like the idea of scheduling when we’re home at night.
Highlighted
We've got 2 iPhones set up for geofencing. The app says our devices are in the zone, but the cameras remain armed. The constant motion alerts when we're at home are driving us nuts. Been loyal Arlo users for a long time and we're super-fans since the system helped us catch an in-progress burglary last year. Three stupid teenagers were arrested and convicted and we got all our stuff back thanks to your amazing cameras. We love you, Arlo! Please, please, please fix this.
Highlighted
I always have my Arlo Pros armed because they are outside but have the Arlo Q set to arm when I leave. It’s been working fine for about 8 months and now geofencing has stopped working. At first it would see I am home when I open the app but now that doesn’t even work. In the app settings location is still set to always allow.
Any help would be appreciated. I sure don’t want alerts all day when I’m home and walking in front of it
Model: VMC3040|Arlo-Q HD with Audio
Highlighted
They’ll get it fixed. It’s just annoying in the mean time.
Highlighted
Any timeline of the fix?
Highlighted
And today the released an update and completely ignored our problem version 2.7.10 and still broken
Highlighted
Same issue. Issue persists after update iOS app to 2.7.10.
Highlighted
Geofencing was working great for months but in the past couple of weeks it has been semi-working.  Whenever we leave the home zone, Arlo will go to Away mode and arm the cameras.  But when we get back into the home zone, Arlo will not go to Home mode.
To get it to Home Mode, I have to open the App, change the mode to something other than Geofencing and then change it back to Geofencing.  When I do that, Arlo will then recognize I am in the home zone and go into Home mode.
It’s strange that Geofencing can identify when I leave but not when I come back.
Anyone else having this issue?
Highlighted
Yep, same here. Was working fine for years. It just started happening recently.
Highlighted
iOS app v2.7.10 did not fix Geofencing problem started since 20th/21st May update
no new Android App yet
Highlighted
It’s not triggering home status when coming back into zone. Triggering away is fine. The only way to get it to trigger is to manually change from geofencing to disabled and then back to geofencing. Then it registers as home. The latest app update didn’t fix.
Highlighted
The geofencing on my app isn’t registering when I come home. It seems to correct itself when I change it to arm then back to Geo fencing, it registers that I’m nearby and disarms itself then when I leave it then I arms itself. But whenever I come back it fails to disarm. I’ve checked the devices and mine is checked, and I’ve uninstalled and reinstalled the app but no such luck
Model: VMB3000 | Arlo Base Station
Highlighted
It seems there was an update today but this has been going on for a while, and was not corrected by this update for iOS. 2.7.10(91)
Highlighted
Same issue here as everyone else is reporting. App shows that our phones are in zone but cameras are still armed. Installed the latest app and iOS updates yesterday and still having the issue. Eagerly waiting for a solution. 😭
Highlighted
Gosh, we can’t even get a “we’re aware of this issue and are diligently working to fix it’” from them. Yet alone get an actual fix. If I ran my company like this I’d be out of business.
Highlighted
I think we can safely assume that.
Highlighted
Hero
Hero
It may be difficult to find in the sea of replies here, but one of the moderators has acknowledged the problem and the fact that it is a top priority.
Highlighted
Arlo moderator JessicaP posted this yesterday "Our development team is investigating reports from users who are not able to use Geofencing as expected and will provide updates when available. We appreciate your patience and apologize for the inconvenience." That was the first acknowledgment by Arlo that I saw.
