My geofencing does not disarm when I come home. It only arms when I leave home, but it often fails to disarm when I return home. Why does this happen? I never had any problem with arlo with galaxy s6 but I am having so much problem with arlo pro and galaxy s7.
7 REPLIES 7
make sure on the S7 the 'power saving feature" is not shutting down the app or gps.
If either one is off, the cameras will not disarm
Thank you TomMac. I checked it with my phone under settings-battery-app power monitor and none of my apps were checked to save power. So I still wonder what is causing it.
What OS? By default, user installed Android apps all have battery optimization enabled.
Galaxy S7, Samsung-SM-G930V, Verizon, Android 7.0 is the details of my phone. thanks.
I just looked at my Nexus 6 settings. There are only 4 system apps in the Not Optimized category. All others are Optimized. I expect yours is similar. Change Arlo to NOT Optimized to see if there's a difference.
Galaxy s7 menu does not seem to have "optimized/ not optimized "menu. I could find only the 'app power monitor' and none of the apps were checked to save power. I wonder where you find optimization menu.
Phone settings, Battery, three dot menu at the top, Battery Optimization
