Find deleted videos
Anybody know if/how I can get back video clips that I deleted?
If you deleted the clip, it usu is gone, any clips thought of wanting should be d/led....
I also recommend peopl do not delete as the files will auto delete at the end of your service days.
NOW, there MAY be a chance you can get a clip back....it has happened 2x-3x in the past ( couple yrs ) and also depends on how much you want it as it will cost a small amount of money. It also may no longer work, so the choice is up to you.
Depending on how far back you want to go ( up to a max of 60 days ) sign up for ONE MONTH of the next higher service level ... 1st is 30 days, next is 60. Once you do this , the files MAY appear in your library up to the 60 dyas max.
IF you do this Plse let us know if it still functions the same.
