I cannot change the field of view on my Arlo Pro camera. When I go into the app, I know how to zoom the view but when something moves outside the zoom but within the normal view, the camera still goes off. How can I set my camera so it only triggers when there is movement within the area I want (a portion of normal view)?
Message 1 of 5
851
It's not the app. You either need to have the cameras plugged into AC power or subscribe to Arlo Smart.
Message 4 of 5
827
Basically you can't... unless you are using zones.
When the camera's picture is pan/zoomed smaller the PIR that detects motion still covers the entire original FOV.
Message 2 of 5
831
Thank you for replying.
Is there a way to do zones? I’m sure that the old legacy app had a feature to do it. Not sure why they would reduce options and give us less choice with the new app.
Message 3 of 5
829
Message 4 of 5
828
Thank you. I did used to subscribe to Arlo Smart. I guess I will again. Take care.
Message 5 of 5
822
