Is it possible to enable/disable the automatic siren triggering on a camera-by-camera basis? The scenario I'm thinking of is having a couple of outside cameras that *do not* automatically trigger the siren, in addition to having one or two cameras inside the house that can have automatic siren triggering enabled when I'm away.
Is this possible? If not, any suggestions?
Thanks in advance for any help.
The siren is enabled per camera in your rules. Use the Mode tab and click on your base. Edit your modes to enable or disable the siren. Be sure to save.
