- 2
Samsung S10
Check permissions for the app in the phone settings to ensure that access to files and folders is enabled.
s10+
Latest app version and latest version of android. everything is completely up to date. 41431409 is my case number
Use the Contact Support link at the bottom here. Maybe they're aware of a specific issue causing this.
Hello,
The development team has found the issue & a fix will be coming soon. I will provide another update as soon as possible.
Arlo app version 2.13.1_27040.
Thanks you.
Hello,
This issue with downloaded videos appearing as a .bin file should now be resolved. Please download the latest version of the Android app version 2.13.1
If you still experience an issue please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
- 2
