For the past 7 days since the app updated, I have received double push notifications (which I have seen numerous threads on), but I am also unable to view video in the App (live or recorded) or on the cloud. All of the camera feeds just show the last video recorded 7 days ago.
This is ridiculous. Fix the problem you broke.
It WAS both. I physically disconnected the base unit, waited 30 seconds, and plugged it back in, and now everything seems to work again.
I’m experiencing the same. This may be fixed some day but will be plagued with other problems forever.
Hi acctprof and harley239,
What phone device are you using? Have you tried reinstalling the Arlo app and rebooting your phone device to see if that helps?
For no video recording on your library, are you not seeing any recording through the web client on your computer?
I have an iPhone 8 and the latest Arlo app. I have not tried reinstalling the Arlo app but I have rebooted my phone multiple times. However, the issue doesn't seem to be with my phone because I see the same dated videos (now 8 days old) online as well.
Our development team is aware about the double notifications on iOS: Double Push Notifications on new release 2.9 Arlo app
Could you clarify on what you mean that you see the same dated video online as well? Are you not seeing your recent recordings from the library?
I am also unable to connect to the camera if I try to play the live feed.
Thanks for clarifying. Are you not seeing any previous library recordings or having problems to connect to the camera from the web client on your computer? You can try to reboot your Base Station to see if that helps.
