Does anyone have solution to make the Arlo Pro cameras functional below -20 Celsius??
I ordered the skin but I don't think it will help much under this kind of weather we get in canada sometimes. this kind of weather doesn't usually last for more than few days but you never know what could happen during this time when the cameras are down do to the cold. MAYBE NETGEAR SHOULD COME UP WITH A WINTER CASE FOR IT ??!! If anyone can help please let me know.
for now I just turn them off and keep some of them inside until the temperature goes back up a bit, otherwise anyone could steal them
Only thing I have seen from my tests is that the Arlo camera does function below -20c/-4f when the Pro stops ( using li-ion 16340 cells )
TBMK, The -20c cutoff is set in HW and in my snooping there's no way to change.
