Do the Arlo pro cameras require a separate base station and if so can the two different base stations be integrated into the same system?
Arlo and Arlo Pro cameras will work with either base unit...
You can use more than one base if wanted... It is the only real way to expand your coverage area. They will both appear in the prgm/app but each unit is its own system..ie; each must be armed / scheduled/ etc separately
